Author Topic: Rear swaybar  (Read 52713 times)
Re: Rear swaybar
« Reply #15 on: February 22 2012, 09:30:37 AM »
The price is certainly right.   How is the daily driving?  It should be better if the rest of the suspension is in good shape...or so I would believe :)
ON my car
Daily driving and up and down movement is very good
here it comes BUT you need to get use to it as it feels like a strange over steer????
i can now launch the car straight with NO air bags and take a 30 MPH turn at 60 or better with little to no lean.
i have two videos one with out and with and you can clearly see the BIG deference.
How is the ride quality?
Offline TURBOPOWERED68
  • David
Re: Rear swaybar
« Reply #16 on: February 22 2012, 10:50:30 AM »
Re: Rear swaybar
« Reply #17 on: February 22 2012, 11:12:38 AM »
I want comfort - my main use for the car will be cruising, very little track runs.
Re: Rear swaybar
« Reply #18 on: February 22 2012, 11:17:44 AM »
If the sway bar is connected to the axle and the frame it won't change the ride at all Mark, except in corners. If it attaches to the lower arms it can because it will creat a binding issue with the suspension.
Re: Rear swaybar
« Reply #19 on: February 22 2012, 11:31:54 AM »
it does add to the spring rate so that on a wavy, or irregular, road, it will stiffen up the ride a bit, but that can be a good thing when conditions get bad and you need ride control.
Offline Tim Hensley
Rear swaybar
« Reply #20 on: February 22 2012, 01:51:23 PM »
Mine is set on the stiff setting for the track it drives different enough I'm working on a way to make it easer to adjust from stiff setting to the soft to and from the track
DLS 210-210
Champion irons
  • David
Re: Rear swaybar
« Reply #21 on: February 22 2012, 05:19:32 PM »
OK your driving down the Highway cruising at 65-70 Mph and a turn comes up guess what, your not leaning all over the place it sits nice and level.
Re: Rear swaybar
« Reply #22 on: February 22 2012, 05:23:48 PM »
I like that!
  • David
Re: Rear swaybar
« Reply #23 on: February 22 2012, 05:30:37 PM »
I like that!
and for under $200.00 shipped its even nicer.
Offline Tim Hensley
Rear swaybar
« Reply #24 on: February 23 2012, 12:24:05 PM »
what setting are you using driving down the highway
I am here: http://maps.google.com/maps?ll=19.703799,-155.061717
DLS 210-210
Champion irons
Re: Rear swaybar
« Reply #25 on: February 23 2012, 02:15:42 PM »
And I am jealous
  • David
Re: Rear swaybar
« Reply #26 on: February 23 2012, 04:44:18 PM »
i have mines on the stiffest setting with NO pre-load.
Re: Rear swaybar
« Reply #27 on: February 24 2012, 12:27:41 AM »
Which shop are you at?
AJ___
Offline Tim Hensley
Rear swaybar
« Reply #28 on: February 24 2012, 03:16:15 PM »
How do I shut off I'm here goggle map
DLS 210-210
Champion irons
Offline Tim Hensley
Rear swaybar
« Reply #29 on: February 25 2012, 01:05:35 AM »
Finally got my mod on the Hellwig bar to make changing the setting much simpler.
DLS 210-210
Champion irons
