Author Topic: Mini starters?  (Read 37594 times)
Re: Mini starters?
« Reply #15 on: September 05 2011, 11:00:57 AM »
the ones sold by tbs
Re: Mini starters?
« Reply #16 on: September 05 2011, 11:55:07 AM »
Thats where mine came from.
My friend had his motor die but the housing is fine so one day I'll build one with the good parts from each one. I think I have too many starters now! ;)
Offline Turbodave
Re: Mini starters?
« Reply #17 on: September 05 2011, 01:32:20 PM »
The first one's ok and the second one is the one I've been using Mark. It'll work fine and it will also work on small and big block buicks as well. If I remember right the V6 and V8 all have the same tooth count. 162 if I remember right.
Forgot to add that the first is a PMG starter and the second one is a gear reduction type so it usually spins faster.
Interesting.  I just counted the teeth on my original flexplate and there's  160.
TurboDave EWCS(SW) USN (Ret.)
Sevierville, TN
Re: Mini starters?
« Reply #18 on: September 05 2011, 02:09:31 PM »
You should try one of their alternators... no...wait.
Re: Mini starters?
« Reply #19 on: September 05 2011, 02:32:39 PM »
Thanks Dave. I wasn't sure like I said.
Re: Mini starters?
« Reply #20 on: September 05 2011, 04:44:57 PM »
Just remember, there is no voltage on a ground wire!  That is what he said....I went out and saved a bunch of weight by removing all the ground wires in my cars after being informed of that factoid.
Re: Mini starters?
« Reply #21 on: September 05 2011, 05:13:47 PM »
I suppose the fuel return line is next to go?   :O
Re: Mini starters?
« Reply #22 on: September 05 2011, 07:04:30 PM »
I plugged that when I threw that round emissions can away.  That emissions stuff slows you way down.  Got it right after the air pump
Offline gordyzx9r
  • The Sultan of Swank
Re: Mini starters?
« Reply #23 on: September 06 2011, 11:24:05 AM »
Too late...I have one of those too.
Offline deathraider6996
  • PSI: -1
Re: Mini starters?
« Reply #24 on: April 29 2016, 04:35:54 PM »
Is this the one Charlie? Seems, wrong haha. I used the part number from the first post and it came up with this one. TIA
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Duttneck Intercooler
3200 Vigilante Converter
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
  • PSI: -1
Re: Mini starters?
« Reply #25 on: April 29 2016, 07:30:36 PM »
Sent from my SM-N910T using Tapatalk
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
Re: Mini starters?
« Reply #26 on: April 29 2016, 10:23:46 PM »
That's the one I was talking about. :rock:
  • PSI: -1
Mini starters?
« Reply #27 on: April 29 2016, 10:57:04 PM »
Thanks!
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
