Author Topic: OEM rear fillers  (Read 51971 times)
Offline Iownagn-gs
OEM rear fillers
« on: July 05 2011, 03:18:44 PM »
The body shop that installed my new GM fillers could NOT get them to fit right. They are way too tight where the fillers go between the taillights.  Right now, the fillers are slightly kinked on the ends mostly at the left and right sides of the tail light area.  Is it possible to use a heat gun and bend the ends of the tail lights just enough to eliminate the problem?  Not sure if this may be part of the problem, the date stamp on the tail lights is 1984 and my GN is an '87.
Thanks,
Walt
OEM rear fillers
« Reply #1 on: July 05 2011, 03:45:23 PM »
Are they genuine GM fillers? You shouldn't need to do any heating, cutting, etc. First thing that comes to mind is to use more bumper mounts shims. The date stamp doesn't make a difference. Did you take a look at them? Maybe they are making a mistake.
Offline Iownagn-gs
Re: OEM rear fillers
« Reply #2 on: July 05 2011, 04:24:23 PM »
I'm heading over to BS shortly, I'll take a few shots and post them.  I can show the areas I'm talking about.  The tops of the fillers sort of fit into the bottom area of the tail lights.  These are the areas that are real snug against the fillers.  I'm pretty sure there is no room for movement either with the fillers or the tail lights.
To be continued.
Walt
OEM rear fillers
« Reply #3 on: July 05 2011, 04:40:31 PM »
That would help a lot.
Offline Iownagn-gs
« Reply #4 on: July 05 2011, 07:44:34 PM »
Got a few pics here.  The very tops of the fillers are tucked inside the bottom of the tail light lens framing.  There is NO way this can be correct.  the Geometry isn't there.
Both parts seem to be equal in length, therefore, one is not going to fit into the other without something bending and this is exactly what is happening to the softer fillers.
If left uncorrected, my 750.00 fillers are going to be trash!  I am seriously pissed off!
I can't remember, but, do the tops of the rear fillers  butt up against and mate with the bottoms of the tail lights?
Getting desperate,
Walt
Getting an Internal Server Error, won't let me send any pics
OEM rear fillers
« Reply #5 on: July 06 2011, 12:07:50 AM »
Pics may be too large. Email them to me and I will post. ihadav8@gmail.com, or load them onto Photobucket and link.
OEM rear fillers
« Reply #6 on: July 06 2011, 12:25:46 AM »
Quote from: "SuperSix @ Tue Jul 05, 2011 11:07 pm"
I tried to post some pics the other day and got the same error and the pics were smaller than the max listed on the page.
AJ___
Oh that was the reason I posted that link as I figured something was wrong.
« Reply #7 on: July 06 2011, 08:06:53 AM »
I will look into it. Right now, I am trying to figure out the bumper filler issue.
They seem to be too wide - I would pull the bumper, and and dry fit everything, measure the tops of the fillers vs the bottom of the lights, and generally check all mounting points.
*I* think the body shop has them mounted wrong. And these are genuine GM fillers, NOT aftermarket?
Offline Iownagn-gs
« Reply #8 on: July 06 2011, 08:51:22 AM »
Yes, they are NOS GM fillers.  They also installed NOS GM to the fronts and they look perfect.  I thought when the fillers are mounted, that's it, no adjustments, nothing, just perfect looking?  $700.00 for the rear fillers and I get this!
OEM rear fillers
« Reply #9 on: July 06 2011, 09:02:51 AM »
That's assuming the tail light assemblies, brackets and bumper are mounted correctly.
Offline Iownagn-gs
« Reply #10 on: July 06 2011, 09:58:13 AM »
U first name Mark?  Thanks for your time, so, what you're saying is, with more time and patience, this can be corrected?  Wonder if anyone else has had this experience?
Now, looks like I need another tail light assembly for passenger side.
It never ends!
« Reply #11 on: July 06 2011, 11:17:54 AM »
Quote from: "Iownagn-gs @ Wed Jul 06, 2011 8:58 am"
U first name Mark?
OEM rear fillers
« Reply #12 on: July 06 2011, 11:30:58 AM »
Can you show us a pic at a different angle? (reflections obscuring some of the detail)
OEM rear fillers
« Reply #13 on: July 06 2011, 11:32:00 AM »
Gimme a minute, I will pull the pics he emailed and link.
