Author Topic: My GN needs a cam. Recommendations, manufacturers?  (Read 84364 times)
Offline Spoolin'
« on: January 06 2011, 05:58:22 PM »
What sounded like a sticky lifter turns out to be a flat lobe on the cam. My engine has about 6000 miles on it, and when it was built a Poston cam was installed. The cam I currently have I do not know the numbers on it, but it is two stages up from a stock grind. I don't mind it, but with my mods it doesn't really gain me anything either.
Here are my mods and what I am planning to add this spring. I'd like to get some input from the GN guru's here that have more experience with these turbo v6 cars since this is my first one.
Current Mods
-.030 rebuild
-cold air intake
-36# injectors
-ATR Pitbull chip
-Adjustable fuel psi regulator
-Fuel pump hotwire kit
Mods to come:
-Turbo Tweak chip
-3" Single Exhaust w/3" downpipe
As you can see, I have and what I'm going for is merely a bolt-on car. I want something that is quite driver friendly as I drive this car to work almost every nice day in the summer, heavily on the weekends, and to and from my girlfriend's house which is 40 miles away, so I don't want to take away any of the fuel economy either (I lose enough thru the gas pedal
« Reply #1 on: January 06 2011, 06:04:24 PM »
Silly question, but why not a stock cam?
Gurus - are the stock cams worth a crap?
« Reply #2 on: January 06 2011, 06:22:31 PM »
For your setup, I would not get too wild with cam selection.
Offline Spoolin'
« Reply #3 on: January 06 2011, 07:15:12 PM »
Quote from: "SuperSix @ Thu Jan 06, 2011 5:04 pm"
That's my question also. The way I see it, a stock cam would be fine for my setup.
Offline Spoolin'
« Reply #4 on: January 06 2011, 07:18:45 PM »
Quote from: "Top Speed @ Thu Jan 06, 2011 5:22 pm"
« Reply #5 on: January 06 2011, 08:53:36 PM »
One step up, two steps up...I love it when you guys get technical!
this is my recommendation   http://www.fullthrottlespeed.com/itemdesc.asp+ic+001BU208CAM+eq++Tp+
remember you must get all the debris from the old cam out, or, you will be doing it again shortly
« Reply #6 on: January 06 2011, 09:11:03 PM »
we were waiting for a real gooroo to show up
Offline Spoolin'
« Reply #7 on: January 06 2011, 10:38:43 PM »
Quote from: "Steve Wood @ Thu Jan 06, 2011 7:53 pm"
« Reply #8 on: January 07 2011, 12:55:27 PM »
As Steve said also said make sure you clean out the block. That lobe material needs to be boiled out of the block. Also get a new oil cooler if you had one or remove it. Also try and figure out why it wiped after 6000 miles or it may happen again.
« Reply #9 on: January 07 2011, 02:09:30 PM »
Quote from: "ULYCYC @ Fri Jan 07, 2011 12:55 pm"
This is why I keep my stock cam - way too many stories about wiped cam lobes with aftermarket. (Well, that, and I don't need anything more aggressive than stock)
Why is that?
« Reply #10 on: January 07 2011, 02:25:41 PM »
99% of failed aftermarket cams appear to come from poor installation/break in techniques or sorry imported lifters that are not properly hardened.
The stock cam is matched very well to the stock turbo.
Offline Spoolin'
Re: My GN needs a cam. Recommendations, manufacturers?
« Reply #11 on: January 07 2011, 03:00:08 PM »
I checked a few other manufacturer's out, but this morning I placed an order the 208 cam, lifters, and pushrods from Full Throttle. Should have parts next week sometime.  :cool;
Its hard to say why that cam got wiped out so early, but as Steve said without a larger turbo and better flowing heads, a cam with more duration won't do any good. The guy doing the R&R for me owns probably the best independent shop around these parts, is a gearhead to the end, and the only guy I trust to work on my cars other than me. We have discussed cleansing the block, and he made the same mention as ULYCYC.
I can't wait to get it running right and install my new tranny.... Then let it sit for the rest of the winter  :rolleyes:
I will have a BRF core for sale in the near future if anyone is interested.
Again, thanks for all of your help fella's  :cool;
« Reply #12 on: January 07 2011, 03:01:01 PM »
Maybe you can recommend good lifters to go with his cam purchase?
Thanks for clearing up why they wipe.
« Reply #13 on: January 07 2011, 03:05:54 PM »
If your heads and or block been machined the over the counter pushrods will be too long. Get a pushrod length checker to make sure. This may have also wiped out your first cam.
« Reply #14 on: January 07 2011, 03:23:06 PM »
Quote from: "SuperSix @ Fri Jan 07, 2011 2:01 pm"
altho expensive, I prefer GM lifters.  According to the mags there Johnson and someone else are once again making lifters in this country.
The original GM lifter had a stelite foot on it...hopefully they still do.
I think Earl had some information on such at one time
