Author Topic: accumulator ball or pm?  (Read 22294 times)
Offline firebird_1252
  • PSI: -1
« on: July 03 2009, 08:42:03 PM »
first off.. i dont want to do a vac brake conversion. when i hit the brake the brake light goes on and i have a hard pedal  little to no brakes then once the light goes out it'll fall and have brakes fine. to my understanding this is the accumulator ball. so.. do i just swap the ball or the whole pm?
87 GN- :D
Offline 87natty
« Reply #1 on: July 03 2009, 09:29:02 PM »
Sounds like the ball to me, I just bit the bullet and went to vacuum. Couldn't find an accumulator for less than $250, and if you do find one, Lord knows how old the damn thing is.
  • PSI: -1
« Reply #2 on: July 03 2009, 09:42:54 PM »
i know brian has them for $189. i just dont want the problems that go along with the vac. brakes i dont have patents to deal with vac leaks.
87 GN- :D
« Reply #3 on: July 04 2009, 08:17:20 AM »
Kirban has the ball for around $179. That's the cheapest if buyng from a store.
Offline straycat990
  • Buickless and Loving It!!!
« Reply #4 on: July 04 2009, 09:37:29 AM »
Quote from: "firebird_1252 @ Fri Jul 03, 2009 8:42 pm"
What problems???  I never had an issue with vac brakes ...now PM brakes ..good god!!! I could write a novel on the problems I have had with that system.
Re: accumulator ball or pm?
« Reply #5 on: July 04 2009, 09:59:25 AM »
Both systems have there ups and downs. If all you need is a ball then just do that. If your PM is still original, its a good chance the motor and pressure switch can be going out too.  To replace the complete PM or VB conversion the correct way can be close in $$$ spent. Either will work fine when done.
  • PSI: -1
« Reply #6 on: July 04 2009, 01:12:35 PM »
ed what do you recomend? i can get the whole conversion kit for 380? from brian.
87 GN- :D
Offline 87natty
« Reply #7 on: July 04 2009, 03:27:53 PM »
I got mine from Red Regal T o TBS for about 200 bones. I still have one of the last PM's made, as I had the entire system replaced a few years back. If my buddy doesn't want it, it's yours. The ball is blown to shit, but it has the right switch and a the entire master is new. Let me ask him.
Offline Recklessrob
« Reply #8 on: July 08 2009, 05:19:38 AM »
You can buy any junk G-body and get the entire  "conversion kit"
really cheap. I kept the entire setup from my '86 Grand Prix just in case.
Remember that you also need the pedal assembly too.
However, I'd try fixing the powermonster first ...
Rob
« Reply #9 on: July 08 2009, 12:40:50 PM »
+1 on the vacuum conversion.
« Reply #10 on: July 08 2009, 09:07:10 PM »
Quote from: "Top Speed @ Wed Jul 08, 2009 11:40 am"
+2
And it does sou nd like the accumulator. Deos the motor run a lot?
DCEPTCN
  • Guest
« Reply #11 on: July 10 2009, 03:34:01 PM »
Avoid vacuum at all costs, despite what the chum-smugglers above said. Unless you never want build boost on the line again...
Was there ever any news about a new aftermarket company making PMs again? I thought I'd heard whisperings. Up until a few years ago you could get an entire new PM from AutoZone with a lifetime warranty for around $350...I wish that deal would come back- as soon as it does I'm putting a .270 round through the vac setup before I switch back.
  • PSI: -1
« Reply #12 on: July 10 2009, 09:11:20 PM »
Quote from: "SuperSix @ Wed Jul 08, 2009 8:07 pm"
+2
nope. only when you hit the brake and again when the pedal falls to normal
87 GN- :D
  • PSI: -1
« Reply #13 on: July 10 2009, 09:12:23 PM »
Quote from: "DCEPTCN @ Fri Jul 10, 2009 2:34 pm"
this is exactaly what i'm worried about
87 GN- :D
Offline straycat990
« Reply #14 on: July 10 2009, 09:18:59 PM »
WTF ??????
