Author Topic: What am I up to...  (Read 10046 times)
Re: What am I up to...
« Reply #15 on: January 07 2018, 05:26:17 AM »
See if this works.
« Reply #16 on: January 07 2018, 08:09:16 AM »
Thanks Rich!
All the internals sitting on the bench. Kind of threw them up there as I was in a time crunch.
Recipient will be this 86 short wide. Solid inside and out. Surface rust on the cab roof.
« Reply #17 on: January 07 2018, 08:18:16 AM »
Thanks Rich!
Daveismissing will start drooling when he sees the patina...
« Reply #18 on: January 07 2018, 09:21:52 AM »
My brother had an 85. It was black and loaded. We put a trans in it then it threw a rod through the side of the block. So he bought a remanned 5.2 I think it was . I know I goofed with the carb a bunch after he got it in and such. I kept asking him what he did to it to get it so far out of adjustment. He sez he still sees it around midland some times so I guess it is still running.
« Reply #19 on: February 04 2018, 02:42:22 PM »
Block and crank are back from the machine shop. It amazes me that these newer engines don't wear like the older ones. No undersize on the mains or rods and just honed the cylinders.
Still can't up load pics
« Reply #20 on: February 04 2018, 03:43:53 PM »
Text em and ill get em up . See I'm good for something haha.
You going to the motorolex in a few weeks? I saw Ken was posting he was going.
« Reply #21 on: February 04 2018, 06:08:30 PM »
drool....
« Reply #22 on: February 04 2018, 09:45:51 PM »
Thanks Rich!  Sending text
I haven't checked the dates to see if I'm off work. I'd really like to go and work the tune.
I cleaned the block, installed the cam bearings and thru some hemi orange paint on the block. Parts have started to arrive as well
« Last Edit: February 04 2018, 09:51:38 PM by good2win22 »
« Reply #23 on: February 04 2018, 09:54:03 PM »
No prob man.
« Reply #24 on: February 15 2018, 10:53:23 PM »
Looks like the crank and such are in.
« Reply #25 on: February 17 2018, 10:22:42 PM »
Making more progress
« Reply #26 on: February 21 2018, 09:30:09 PM »
Engine is mostly back together with a new bump stick from Hughes engines, new bearings, new rings, new timing chain and tensioner. Heads are engine quest drilled for an LA style intake. That allowed me to pick up an air gap rpm performer intake. Still need to get a carb for the build. Also need to get the old 318 and tranny out of the truck and have the tranny gone thru. Going to use the timing cover off the 318 so I can install a mechanical fuel pump. That's about it for now since I had to go back to work.
« Reply #27 on: February 22 2018, 10:22:24 AM »
Gonna really be nice!
« Reply #28 on: April 08 2018, 12:52:20 PM »
Pulled the worn out 318 and tranny. Dropped the tranny at the shop for rebuild and pulled the timing cover and v-belt drive for accessories off the old engine. Got the old timing cover cleaned up and installed on the magnum. May have some belt alignment issues....
« Reply #29 on: April 09 2018, 07:10:33 AM »
A couple progress pix from Jason.
