Author Topic: Exhaust Header Gaskets? Yea, or Nay?  (Read 2353 times)
Offline ~JM~
« on: September 01 2021, 08:07:38 PM »
Thoughts on the use of a gasket between exhaust header flange & the head?
No gasket?
Copper gasket?
High-temp RTV?
Re: Exhaust Header Gaskets? Yea, or Nay?
« Reply #1 on: September 01 2021, 11:27:14 PM »
For years, I only used a thin smear of hi temp on both sides of the gasket.  These days, I suspect most manifolds have at least a little warp to them.  I would probably suggest the felpro gaskets with a thin smear on both sides of them and let them sit over night before starting.
« Reply #2 on: September 02 2021, 02:01:39 AM »
Felpro 1400 gaskets, dry.
Offline gnonyx
« Reply #3 on: September 02 2021, 08:52:25 AM »
After removing both headers for weld job, machine shop resurfaced with a sand belt both headers from being a little warp, and twice of replacing the Remflex, and copper gaskets, I decided to used Ultra Copper gasket maker from Permatex. Using no gasket is originally from the factory, just use Permatex stuff. I apply about 1/8" layer let is cure a little bit as direction, and then assemble and torque, and don't start until the next day.
87 GN T-Top, ScanMaster, hot-wire kit, Full Throttle chips w/ matching 60# injectors, adj. fuel pump, and triple pod gauges w/ AEM A/F gauge, oil pressure gauge, vac/boost gauge, Kenne Belle rear seat brace, upgraded tranny w/ Art Carr pan cover, and a pre-lube oil system.
« Reply #4 on: September 04 2021, 02:41:29 PM »
I have had good luck with the Remflex.  But no gasket would be the best way to go.  I never even needed sealant till the manifolds started to break in places and I had to weld them up.
Offline Just a Six?
  • OK Now who Farted??
« Reply #5 on: September 05 2021, 02:45:34 PM »
When I put mine together a few months back I used my big file to go over the headers & the heads to hit any high spots (they weren't too bad) put them on without any sealant & so far they sound good although I'm not beating on the car & only have maybe 400 miles on it. Before winter I'll pop them off & see how they look & maybe get some gaskets or some sealer if needed.
David
87 LTD. Purchased May 88
Doeskin leather, coach lites without Landau Roof, moon roof, carpeted trunk & No Factory Hood Ornament!
The sticker on AC shows a V-8 Carb car. Special order by Mr. Nick Hall VP of GM Canada
Runs 11.50 on 21 lbs with my old style 67 Q Trim & Alchy
Offline ~JM~
« Reply #6 on: September 05 2021, 08:21:26 PM »
I've done about the same with a large file. Think I will apply a bead of Ultra Copper RTV.
« Reply #7 on: September 05 2021, 11:52:09 PM »
use it as a glue, not a thick bead for a gasket.  If it is thick, it will get pushed out
Offline ~JM~
« Reply #8 on: September 06 2021, 12:04:17 AM »
Thanks
