Author Topic: Rear end oil change  (Read 5058 times)
Offline Shimy87
Rear end oil change
« on: October 18 2017, 07:25:20 PM »
What should I refill rear with??
Re: Rear end oil change
« Reply #1 on: October 18 2017, 10:23:35 PM »
I grab posi additive and gear lube from my GM dealer here in town. I've been beating on that Auburn Pro Series unit for 7 seasons...and it's still hanging in there...so I must be doing something right.
« Reply #2 on: October 18 2017, 10:46:36 PM »
Shimy, if the funds are there...grab a diff girdle. It's cheap insurance. I have the one from Jeremys yellow car on mine...along with his dual fan setup.
Offline 1KWIKSIX
« Reply #3 on: October 19 2017, 07:18:45 AM »
X2 I'm with Brad .
Here's what Auburn say about oil for their differentials. ....this is also what I run in my Auburn Pro Series rear end.
Obviously you can substitute the Auburn Gear Friction Additive with the GM product.
Non-Synthetic 80w90 GL-5 oil treated with Auburn Gear friction additive, part #504102 (also known as a friction modifier). Three (3) ounces of additive will treat one quart of oil. GM or Ford limited-slip additive may be used. We do not recommend synthetic oil.
« Last Edit: October 19 2017, 07:10:13 PM by 1KWIKSIX »
« Reply #4 on: October 19 2017, 10:39:09 AM »
 If you have a stock posi I like synthetic gear dope.   Don't add the whale jizz additive unless you get chatter.
« Reply #5 on: October 19 2017, 12:07:28 PM »
Has anyone seen an aftermarket diff unit manufacturer that recommends a synthetic? I know eaton does not recommend synthetic
« Reply #6 on: October 19 2017, 02:43:48 PM »
Do they not recommend it, or recommend against it?
Offline gusszgs
  • Limited quick brick
« Reply #7 on: October 19 2017, 02:50:31 PM »
Just redid the clutch packs in my T. Got them from Bruce Ponti. He's been doing rear ends for yrs and said Dino 75-80/90 with Posi Gm additive
Jim
1987 T Limited
« Reply #8 on: October 19 2017, 04:05:21 PM »
From what I gather synthetic will 'fall' off if the car sits any length of time.
« Reply #9 on: October 19 2017, 04:41:48 PM »
I'm pretty certian eaton recommends against using synthetic
« Reply #10 on: October 19 2017, 06:39:16 PM »
Shimy, while you're under there ya' may as well toss a set of Moser axles in it. Only a few more minutes work. If the wife starts complaining... give 'er the choice of axles or you pissing the cash away on peelers.
Offline Shimy87
« Reply #11 on: October 19 2017, 09:28:19 PM »
 :icon_lol:   :cheers:
« Reply #12 on: October 20 2017, 11:43:58 AM »
I wonder if that recommendation is because they would sell less additive?
My stock posi chatters with dino and doesn't with fully synthetic.
Since I've got over 1/4 million miles on my stock rear end on synthetic, I think I'll ignore the advice and stick with what I've got.
« Reply #13 on: October 20 2017, 02:31:05 PM »
Earl my question was about aftermarket diff manufacturers
« Reply #14 on: October 20 2017, 03:23:01 PM »
Good question.  All I know is my posi with the synthetic no longer works as good as it use to.  Sometimes I question if I even have a posi!  Sucks especially in the Truck with ice and deep snow.  It works but takes much longer to lock up. :(
