Author Topic: This explains a lot  (Read 8741 times)
This explains a lot
« on: June 17 2018, 11:05:03 PM »
This post is going to ruffle a few feathers but I assure you it is NOT directed at anyone in particular just a pet peeve of mine.
HERE is a time slip for a hellkitty Notice it picks up 27 mph on the back half on 9.70. My GN would pick up 26 mph on the back half at 19 lbs of boost Can i say that equates to a 9.80 run?
If I turned it up it would equate to an 8 sec. car.[size=78%]
[/size]
Re: This explains a lot
« Reply #1 on: June 18 2018, 08:26:42 AM »
Looks like a 9.95 to me, where does the 9.70 come from?
Pretty salty with a 1.5 60'. Obviously has a bunch once it gets rolling.
« Reply #2 on: June 18 2018, 08:32:30 AM »
perhaps you should state what your point is?  I'm a bit lost on this one.
« Reply #3 on: June 18 2018, 08:33:19 AM »
x2
« Reply #4 on: June 18 2018, 09:16:28 AM »
My point is the people who run 1/8 mile and say their time equates to something 1/4 mile. So to make a point I am going the other way and saying my time equates to a 9 sec run.
There was another time slip at 9.7 but was too large. Thats where the 9.70 comes in.
1/8 time does not equate to anything. It runs what it runs.
« Reply #5 on: June 18 2018, 09:32:38 AM »
Grab one of your timeslips and run the equation for your 1/8th ET and 1/8th MPH. It'll almost mimic your 1/4 ET and 1/4 MPH.
« Reply #6 on: June 18 2018, 09:50:16 AM »
I don't agree with that statement. And definitely not in my case. In my case if the front half equalled the back half then it's a 9 sec car And ain't no way in hell.
 Show me the time slip. IF you run the 1/4 and use the 1/8 time from that slip then OK .
« Reply #7 on: June 18 2018, 10:00:32 AM »
Here's the post from my 6.7 at 105 run...timeslip included. Now...you'll note I folded the timeslip over. Reason being...is that I didn't want the locals to know how fast the car was. I coasted from the 1/8th...and it went through the 1/4 traps at 11.2. It doesn't take a rocket scientist to figure out what the car will do as far as the 1/4 is concerned. SMP has a short shutoff as Dan Keller and Justasix will verify. Dan Keller and I have stopped at 123...but it's a handful. We run the 1/8th for safety reasons.
Post your timeslip...and let's compare what your 1/8th MPH and 1/8th ET is compared to mine.
http://www.ihadav8.com/forum/index.php?topic=4790.msg67857#msg67857
« Reply #8 on: June 18 2018, 10:06:59 AM »
« Reply #9 on: June 18 2018, 10:10:25 AM »
7.77 in the 1/8 at 96mph and 11.5 at i23 in the 1/4
http://www.wallaceracing.com/hpcalculatorquarter.php
http://www.wallaceracing.com/hpcalculatoreigth.php
You're a full second behind me at the 1/8th...and your MPH is far lower. MPH is indicative of HP. It all comes back to low gear tuning. You left alot on the table.
« Reply #10 on: June 18 2018, 10:27:08 AM »
 Yes I know but that is a street car IE no slicks. no race gas. 3800 lbs and drive to the track as much as 200 miles 1 way.
Low gear tuning won't help with no traction.
plenty of hp picking up 26 in the back half at 19 lbs of boost.
A non turbo car set up for the 1/8 won't run good in the 1/4 for example. or vice versa that is the point here tho. I have nothing to prove. but bench racing is fun too
Did you compare the wallace links.
« Reply #11 on: June 18 2018, 10:31:54 AM »
Actually, low gear tuning will help with traction. Add some low gear fuel or pull a little low gear timing. Most don't know how to tune for track conditions. I don't need a calculator to know what 6.7 at 105 is. It's flat out flying.
« Reply #12 on: June 18 2018, 10:33:02 AM »
If the power band is linear than the 1/4 mile estimates will be true.  But if you have a 3 staged Nitrous kit or a big turbo Supra that takes the 1/8 mile to be fully spooled the calculator is out the door!
« Reply #13 on: June 18 2018, 10:46:30 AM »
 I'M not disputing that fact but i don't agree that equates to a 10 something in the 1 /4.
THe calculator [wallace link] shows hp in the 1/8 and 1/4 so if you add them together it equates to a 9 sec run.theoretica lly but I deal in realty not fantasy.
« Reply #14 on: June 18 2018, 10:57:21 AM »
MPH is indicative of HP. I'll leave it at that.
