Author Topic: Break in Oil?  (Read 3647 times)
Break in Oil?
« on: June 03 2018, 06:41:31 PM »
I was thinking of just putting in my Pennzoil Race oil.  I was going to use Rotella but I was told that it has more detergent and less ZDP in it.  I have a roller cam so I don't have to worry about that.
What do you guys think?
Re: Break in Oil?
« Reply #1 on: June 03 2018, 07:15:47 PM »
You have a roller cam...
Re: Break in Oil?
« Reply #2 on: June 03 2018, 07:39:11 PM »
there is enuf zddp in your oils to cover push rods and other rubbing surfaces.  No need for Break In oils
Re: Break in Oil?
« Reply #3 on: June 03 2018, 07:55:56 PM »
There's some idiot up in Canada uses Rotella and Wix filters. Saw a vid of his rod bearing after beating on the engine like a seal pup at his local track every weekend. Bearing looked brand new. Heard a rumour the moron uses a flat tappet cam too.
Re: Break in Oil?
« Reply #4 on: June 03 2018, 08:53:14 PM »
What I really wanted was to use a cheaper oil for breakin.  I think I still have some Rotella left.  I was thinking of putting 200 km on the motor and dumping the oil before putting the race oil in.
Aren't wix the filters you want to use?  Nothing wrong with being a moron as long as your a helpful one! :cheers:
Re: Break in Oil?
« Reply #5 on: June 03 2018, 09:03:48 PM »
On my own engines I break the cam in...dump the oil and filter...and head straight for the track. Dan and I slather the cam and lifters with cam break in lube. Pushrods, rockers, timing chain etc get drowned in GM EOS.
Re: Break in Oil?
« Reply #6 on: June 03 2018, 09:12:57 PM »
Bearings will last forever. All you have to do is monitor for KR...and stay out of it. I've never understood how guys will go out and spend a gazillion dollars on cool guys parts, chrome etc, but refuse to spend a couple of bucks on Powerlogger. Or how the knock gauge is going off like xmas tree lites on the a-pillar in their line of vision...and they keep their foot in it. I don't know how many engines Dan and I have pulled. Each and every one of them...except mine...have had the rod bearings pounded into tin foil.
Re: Break in Oil?
« Reply #7 on: June 04 2018, 08:09:14 AM »
I always love hearing that's it's standard to have ''initial timing chain stretch" like it's set in stone.
The trick with making a timing chain 'not stretch' is to use (motorcycle) chain lube all over the inside before installing.
.....I know, right.....  :)
Re: Break in Oil?
« Reply #8 on: June 04 2018, 08:51:36 AM »
The engine will be broken in by the time you drive it around the block once.  All this break in stuff is from the old days when piston rings were not moly coated/plasma, whatever the term is.  Put whatever oil you want in it, drive it ten miles, 15 kms, and change the oil to look for metal particles fromt eh bearings...go racing
Re: Break in Oil?
« Reply #9 on: June 04 2018, 09:40:48 AM »
What? You mean no bon-ami? to seat the rings anymore ?. JK people lol
Re: Break in Oil?
« Reply #10 on: June 04 2018, 10:43:32 AM »
Maybe I should reword it,  "What is the best oil for a run and dump?" :D
Re: Break in Oil?
« Reply #11 on: June 04 2018, 12:49:40 PM »
Whatever you can find that doesn't have dead spiders in it.
Re: Break in Oil?
« Reply #12 on: June 04 2018, 12:58:54 PM »
Yep. The guys that think you have to have a crosshatch have knocked the moly off the rings within seconds.  'Break in' is done.    Plain iron rings on rough bores. Just like Henry Ford did it. :)
The guys that make the bores as close to a mirror as possible keep the moly and need to load the rings 5 times so they can be married (and in this instance, marriage is actually happy forever after).
Offline Norm340
Re: Break in Oil?
« Reply #13 on: June 04 2018, 01:39:15 PM »
Re: Break in Oil?
« Reply #14 on: June 04 2018, 02:40:11 PM »
Interestingly, spider legs work via hydraulic pressures:http://www.industrialoutpost.com/hydraulic-spider-legs/
