Author Topic: MAP sensor  (Read 5155 times)
Offline aminga
  • Chicks Dig the Power Bulge
Re: MAP sensor
« Reply #15 on: July 15 2018, 03:56:14 PM »
I think you were on the right track to check the map output.  You did check the line from the sensor (vacuum) to make sure it is not cracked or broken?
Here's a link that shows voltages for a 3 bar  http://injector-rehab.com/shop/mapsensor.html
it's about 4.9/3 at atmospheric pressure or 1.6V
86 Regal T-type. One Owner. Twisted 6 Racing Built 109, FTSS Revolution X 206/210 Cam, T&D 1.65 Rockers, Diamond Forged Pistons, RJC Power Plate, TA6262DBB, PTE SLIC, Alkycontrol pump and Kit and ISAC Controller, Bailey TR6 Wastespark, TA Headers, ATR Downpipe, Racetronix Walbro pump and hot wire ki
Re: MAP sensor
« Reply #16 on: July 15 2018, 05:10:48 PM »
Unplug the compressor and blow it down to 30psi.  Then hook it to the MAP.
Earl...didn't Bison do a test on those with different brands?
https://turbobuick.com/threads/failed-3-bar-map-sensor-my-upgrade.451242/#post-3758619
Offline Shimy87
Re: MAP sensor
« Reply #17 on: July 16 2018, 03:59:56 PM »
Well with 0 pressure to it green wire read .25 volts. With 30 and then 40 lbs put to it no change...const ant .25....im thinking I need a new map
Re: MAP sensor
« Reply #18 on: July 16 2018, 04:47:43 PM »
sure sounds like it.  The GM sensor, if real, is the only factory style that I would buy and I suspect if they are coming from China, they are not worth it.  You could try one from Julio as he claims his are the real deal.
I guess the SSI technologies P51 pressure sensor is supposed to be the creme de la creme.  I think Bison is selling a 3.5bar version that he uses. Bout $150 each but is probably worth it if it saves you an engine
Re: MAP sensor
« Reply #19 on: July 16 2018, 04:53:08 PM »
Offline Shimy87
Re: MAP sensor
« Reply #20 on: July 16 2018, 05:25:10 PM »
Called Julio to order one...we talked about it and he had me test it a different way...its good....he walked me through more tests and it turned out to be the factory boost gauge shorting it....eliminat ed that connection as I don't need it anyway and bingo!!  Just wanted to update if anyone searches for this problem they could check that.  Thanks guys!!
Re: MAP sensor
« Reply #21 on: July 16 2018, 07:02:21 PM »
good news
