Author Topic: It's snowing!!  (Read 12448 times)
Re: It's snowing!!
« Reply #45 on: December 28 2017, 12:20:40 PM »
Its damn cold here too. The wind dropped off thankfully.
Re: It's snowing!!
« Reply #46 on: December 29 2017, 12:53:28 PM »
A nice -44 here today with the wind.  Went to my aunt and uncle's out of town for Christmas and I guess my uncles plug in didn't have power.  Truck struggled to start but it did.  Then it went into low power mode, which I never heard of before and I could only get 12 mph out of it.  Luckily I was able to reset the ECM and it worked again, otherwise it would have been a long road trip.
Re: It's snowing!!
« Reply #47 on: December 29 2017, 01:25:49 PM »
Check YouTube. Low power mode is usually the TPS. Happened to one of my trucks.
Re: It's snowing!!
« Reply #48 on: December 29 2017, 02:07:09 PM »
It was actually the low battery that set it off.  I already verified the battery tripped the code.  I put the battery on the charger 2 nights in a row and the check engine light cleared and everything seems good now.
Re: It's snowing!!
« Reply #49 on: December 30 2017, 02:17:13 PM »
Rough morning!  I told my buddy at work, not to lock my truck because I had to reset the power locks and it takes 2 days before it starts working again.  He locked it and my manual lock was frozen.  It was only -44'C this morning.  It took about an hour to get it open but I was able to.  Just before that I looked at a steam coil at work and it was frozen and spitting water out of the bottom.  It probably froze because it couldn't get rid of all the condensation.
Love the cold weather! :(
Re: It's snowing!!
« Reply #50 on: December 30 2017, 03:35:44 PM »
I got no use for winter.
Re: It's snowing!!
« Reply #51 on: December 30 2017, 03:51:11 PM »
As I get older I tend to like it less.  The guy I worked with last night said it was probably colder than where I grew up in the North.  I said, NO!  We would get down to -56'C in over night and warm up to -44'C  and that is with no wind.  Sometimes it is windy and we are in the -60's with the wind.  Now, that is cold!!
Re: It's snowing!!
« Reply #52 on: January 03 2018, 04:27:54 PM »
Calling for -15F to -30F windchills until Saturday.
Re: It's snowing!!
« Reply #53 on: January 03 2018, 06:49:13 PM »
The -34'F is definitely cold!  We had 2 weeks here and still going of -30 to -37'C and with the wind as cold as -48'C.  I spent an hour on a roof at work cleaning snow from an intake which goes to a Research Facility on New Years Eve and I was on the roof a couple more times.  I literally had brain freeze!!  But the Researchers don't like it when there medical research goes bad.
Offline motorhead
  • PSI: 4
  • look at my balls... look at them!!!
Re: It's snowing!!
« Reply #54 on: January 04 2018, 01:54:21 PM »
When it is this cold I like to use it to assemble things which are tolerance fit.  Rearends, rocker arm trunions, etc.
>>>Das Instagram<<<
'80 LeMans Wagon|'87 Monte Carlo SS|'92 Camaro Z28|'07 TrailBlazer SS|'15 Colorado Z71|'19 Hellcat Widebooty M6
